I received an error message while overdriving AMD Phenom Processor with MSI Motherboard. It cannot detect AMD CPU on the computer. I tried several ways to get it ok but failed. If you have any idea for the error message, please help.
Thanks in advance.
AMD OverDrive
AOD cannot detect AMD CPU on this computer.
Hi
I will help you to install the AMD OverDrive software on you AMD powered pc. The reason of this problem is your BIOS. You have to update the BIOS drivers of your pc. If the BIOS is successfully updated you will be able to install the AOD and it will also detect AMD Phenom processors so that you can overclock.
Hello Nelson,
Have you opened your computer lately to do some maintenance? For you may have a messed up a little bit when connecting the components inside the computer. You will need to open the computer and ensure that the cable to the processor has been connected.
Nicke
