AOL Instant Messenger (AIM) failed to demonstrate my friend lists
Hi guys,
Hi guys,
Hi Albertrowfrizier,
Thanks for sharing your problem with us, please make sure that your network connection is working properly or not. If problem continues then try to reinstall the program that you are using. To uninstall make program just go to control panel and select program select the program that you want to uninstall.
I hope this will solve your problem.
Hi Albertrowfrizier, there are ways to find out why the error occurred and how it can be solved. I will refer you to this site.
 Try to check it out and you will find detailed instructions to check the cause of your problem.   Try each guideline one by one and check if it fixes the problem, if not try the next step.
