Hello experts,
I have this weird error. When I try to uninstall AOL Toolbar this error appears. I don’t know what the uninstall has to do an Install.log and how I can make a successful uninstall. Does anyone experienced this kind of error before ? How can I solve this ?
Thank you !
Uninstall
Could not open INSTALL.LOG file
OK
AOL Toolbar for Internet Explorer error trying to uninstall
Hello Frank,
Generally you receive this kind of issue when you were trying to un-install a missing or damaged file. Try scanning the system by opening command prompt and run sfc/scannow command.
Try below solution to fix the issue.
1. Open the installation directory where the program has been installed
2. Find a file named "install.log". Cut paste this file outside somewhere from this folder.
3. Now run the un-installer and it will ask for "install.log", Locate it and uninstall will just work fine.
As a simple method, just download some genuine installer and it will do the work for you.
Good Luck..!!
