Apache Tomcat application for hosting a JavaScript page
Can anyone suggest an application server when hosting a JavaScript page? Would Apache Tomcat application Server be suitable?
Hello Pia, Apache tomcat is one of the most popular webs hosting application. I would definitely suggest it. It is very easy to use. One of the most great advantage of it is it’s an open source AS. It is light weight and you case easily use it any system. Configuration is very simple with Apache. Like Oracle AS it doesn’t require lot of memory at the startup. You should concentrate on which server is faster. Tomcat’s memory footprint is smaller than Oracle WebLogic. So it is faster. For server we always look for a faster one. I would definitely suggest you to choose Tomcat.
Notifications
