API available for giganet cloud
Is there an API available for giganet cloud that would allow to me pull timely information on the status of servers in the gcloud portal? If so, is there any documentations on how to access the API?
Google cloud has this so-called API's console. This allows you to add projct members, handled billing and authentication manager that will definitely works with APIs.
It has its own Google Cloud Storage for instance that support graphical inerface. Allows you to manage and activate Google APIs as many as you want. This has it's own settings that you are able to customized and set to your own liking. Billing activations and deactivations that can be custom designed in API features and authorizations.
This APIs console is designed and consist of projects that needs to be activated in Google API or the service that linked to the project. This projects enables you to perform administrative jobs, billing and in project based tasks.
An example like wise is called api_project which contains activated multiple APIs. When it's enabled, billing api_project all team mebers associated to api_projects should have all the access to perform it's task separately.
