Hi there experts,
I just installed Facebook app on my iPhone 5 and this error appears when I want to open the app. I don’t understand why it says that is not installed. Please is there anyone that can help me to solve this error? What could be the problem? Thanks!
The app “Facebook” was not installed on the iPhone iPhone4w” because the app could not be found.
More Information OK
points
The app Facebook was not installed on the iPhone iPhone4w
This type of weird problem is normal if you have set up different configuration between desktop, laptop etc. and you synchronize Mac system preferences through MobileMe. Here’s how to fix such issue:
1. Stop synchronizing system preferences with MobileMe.
2. Copy all the files from “/iTunes and /iTunes/iTunes Music” to “/iTunes/iTunes Media”.
3. Remove “/iTunes and /iTunes/iTunes Music” to “Trash”.
4. Also, make sure that you have “/iTunes/iTunes Media” as your library in iTunes.
5. Organize iTunes library.
6. Re-download the app that is said missing.
No more trouble will bother you anymore.
After installing the Facebook app on your iPhone, check if the app appears among your apps. You will know if the app installs successfully if you see its icon on your phone. If the icon is not there then the app did not install or maybe failed to install. In this case, try downloading the latest version of the app from the app store.
Download the latest Facebook app from the Apple App Store. The latest version at the moment supports iOS 9.0 and higher. It works on iPhone, iPad, and iPod touch as well as Apple TV. The Facebook app is rated 12+. If your iPhone runs on a lower version of iOS, just visit the link to see if there is an available version for your phone.
