App that will give internet radio for Samsung Wav
I need an app that will provide free internet radio for Samsung Wav, will it be available in Google Play Store,
Please send me a download Link.
Hi David Parfit,
You are looking for internet radio for your Samsung wave. As per your phone specification you are using BADA OS.
As you told about Google play sore, but Google play store is for android application, not for BADA OS applications.
I recommended to you can try the best internet radio which s supports by Samsung wave (bada os): TuneIn Radio
You can download the TuneIn Radio from the link:
I hope it will helpful.
Thanks!
Hello David,
Very rare to get an app that will provide an internet radio for Samsung wav.
There are some but when you look at the download link and the intro of that app, you'll probably upset to some introducing app out there.
So, it is good for you to go for an absolute guaranteed store such as Google Play Store that you can get your app according to your taste.
I can give you a link for you to try and see. Be ready to your device.
Thanks,
Steeley Ney
