Apparently on Samsung Star 2 Skype video calling is not working
Video calling from these devices can be a problem, due to device compatibility. There has never been an official report from skype about this, but the problem exists, and you can solve it only by upgrading your phone software, if the update exists.
If you have a Samsung Galaxy Star 2 Smartphone and you tried installing Skype but it didn’t work, check that you installed the correct version for your device. Your Samsung Galaxy Star 2 runs on Android 4.4.2 KitKat. So, you should install the version of Skype that supports Android 4.4.2 KitKat.
To make sure you will be installing the version that is compatible with your device, you should always download from the Google Play Store. To fix your problem, uninstall or delete the existing Skype app from your phone then download Skype. See if this fixes the problem. The latest version at the moment includes the following new updates:
Share contacts in your conversations.
Stability and reliability enhancements.
Here are the specifications of your device. The Samsung Galaxy Star 2 is a 2G Smartphone operating on 2G network band using GSM technology. It was announced to the public on June 2014 and released on August 2014 measuring 109.8 x 59.9 x 11.8 millimeters and weighing 107.6 grams. It uses two mini-SIM cards and has TFT capacitive touchscreen display at 320 x 480 pixels screen resolution.
It supports multi-touch and runs on Android 4.4.2 KitKat powered by SC6815A chipset and 1 GHz processor. It supports microSD expandable up to 32 GB. It runs on 512 MB RAM with 4 GB internal storage. The primary camera supports 2 megapixels and 480p video recording at 24 fps. There is no secondary camera.
It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with hotspot support, Bluetooth 4.0 with A2DP support, FM radio, and microUSB 2.0. It doesn’t have GPS. It has built-in accelerometer sensor. The pre-installed web browser supports HTML. It runs on removable Li-Ion 1300 mAh battery and available in Iris Charcoal and White colors.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
