worldart
Posted on - 09/21/2011
I have a computer that contains a built in agp card. But recently it damages. For that i have to buy a new agp card for display into the monitor. But the resolution of the agp card is so much low. I cannot get the resolution. I am unable to get proper resolution, my game is not working also for this agp card. How can I install it properly? Can i solve the built in agp card or have any idea about agp card?
Thanks
Worldart
Appearing Strange Behavior From Hardware Component
Different video cards require different drivers for their specific brand. If your previous AGP video card that is integrated in your motherboard is already broken, you need first to uninstall its software before installing a new hardware. I think here you just attached your recently bought AGP video card and thinking that it will also work since they are both AGP types. Nope. You got it all wrong.
Different video cards require their own specific software to run. Before the second AGP video card works, you need first to uninstall the previous AGP card that is originally installed in your computer. After removing its driver, you can now attach the newly bought AGP video card to the available AGP slot and start installing its software.
