Apple AirPort Extreme Error 6753 During Setup
I use an Apple computer. During the setup of my Wi-Fi network, I got an AirPort Extreme Error 6753 prompted by the system. What should I do?
You can configure you Apple computer in the following ways so that you can solve your problem.
You can also enable IPv6 using the network settings of your device.
That means your device is not connected to your computer while you are setting up the program. Your device should be connected to your computer before you start setup so that when the setup wizard starts looking for connected devices, it can immediately detect and access your Apple device. If your device is already connected to your computer wirelessly or via Wi-Fi, make sure it is within range.
Your device won’t be detected if it is out of range. Click “OK” to close the dialog then cancel setup if it prompts you. Next, connect your device to your computer and then start setup again. This should fix the problem. If this doesn’t work, your device can’t be detected. If it is already connected to your computer, try restarting your device.
When the device is ready, start setup again then see what happens.
