Apple iOS 4.3.2 is now available for iPhone4
It is great to know that Apple released its new update Apple iOS 4.3.2.
What are the major changes made by Apple after several issues happened?
The Apple Update to iOS 4.3.2 fixes the FaceTime and 3G wireless connectivity feature to work more better.
This will fix the FaceTime from freezing and connecting to 3G networks on iPads.
It also fixes security updates for iPhone 4, iPhone 3GS and iPad.
These are the major changes from the recent update.
Hi Judith Lauren,
Apple iOS 4.3.2 has the following features:
1. Cloud based media sharing
2. Has an image of iPad home screen with icons of camera and FaceTime
3. Also has a new photo stream sync feature which makes sharing automatic
4. Ability to send push notifications
The above are the new features that were found on iOS 4.3.2. If you would like more details on the same you can check on the link
