Apple iPad Vs Samsung Tab 3
I am considering buying a 10-inch tablet with my main options being either Samsung or Apple. If you are knowledgeable in these two, which one can you advise me to buy? Does the iOS application store have many useful apps like Google play store? How does the iPad hardware compare to the Samsung Tab?
Answered By 0 points N/A #200262
From my opinion, you should go with Apple iPad Air. Because it is mostly ahead than Samsung Tab 3. This device is made of high quality aluminum. It has higher display resolution and better pixel density. It has iOS 7OS.It has better picture with quality with 5 megapixel camera.It has also 128 GB built-in storage capability.There are not a big change between iOS apps store and Google play store.But from hardware conclusion you must go with Apple
