Apple iPad will not start up
I have an iPad that turned off and I plugged it in to charge and it will not turn on at all now. I'm not sure what else to do. I moved the plug/charger to be sure that wasn't the issue, but I can't find it. I hope that there is a resolution because I am getting worried. Thank you for your advice.
Answered By 0 points N/A #191165
Your iPad may have drained its battery. I recommend you to follow these steps:
1. Charge your iPad for at least 30 mins.
2. Hold the home button and Sleep/Wake butto for 10 seconds or so until you see the logo Apple logo appears.
3. If it doesn't boot, try to use your charger and cable on another device and see if it works. If this doesn't solve the problem, best is to bring it to the nearest Apple store as this may be a hardware issue already.
