Apple iPhone 5S Case Design
I already seen the picture of the case of Apple iPhone 5S in a video source. The case is so great and amazing.
Does it have also great interesting features that consumers should know?
The iPhone will be running iOS 6 boasts Darwin Kernel Version 13.0.0. You might also see that the processor is an ARM S5L8950X. Interestingly, the full release above the most current developer version of MAC OS 10.8 Mountain Lion.
The XNU build in iPhone 5 is also higher (21XX vs. 2050.5.8). It possibly has a low powered dual core processor just like iPad 2.
As for GPU, the new iPhone also features something entirely new. It has a GPU chip. The GPU chip, which will continue to be part of the SoC, is called “SGX543RC*” (the asterisk is another sensitive number that could identify people working on the device). This GPU technically does not exist yet and we don’t have specs.
The iPhone 5 will now have 1 GB of RAM, which seems to do well for the new iPad.
This unit runs 6.0 seed 10A33X with iBoot version iBoot-153x.x (iOS 5.* has an iBoot version of iBoot-12xx.x.x, depending on the device and version). It is much taller then the previous version.
One of the versions of the Apple iPhone 5 is iPhone 5s and here are its specifications. The Apple iPhone 5s is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, EVDO, and LTE technologies. It was unveiled to the public and released on September 2013. It measures 123.8 x 58.6 x 7.6 millimeters and weighs 112 grams.
It uses nano-SIM card. It has an LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 1136 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass with oleophobic coating. It runs on iOS 7 upgradable to iOS 10.1 powered by Apple A7 chipset, Dual Core 1.3 GHz Cyclone (ARM v8-based) processor, and PowerVR G6430 (quad-core graphics) GPU.
It doesn’t support microSD. It runs on 1 GB DDR3 RAM with internal storage available in the following capacities: 16 GB, 32 GB, and 64 GB. The primary camera supports 8 megapixels with f/2.2, 29mm, dual LED flash (dual tone), and autofocus. The primary camera features geo-tagging, 1/3″ sensor size, 1.5 µm pixel size, touch focus, face and smile detection, and HDR (photo/panorama).
The primary camera can record video in 1080p at 30 fps and 720p at 120 fps. The secondary camera supports 1.2 megapixels with f/2.4 and 31mm and can record video in 720p at 30 fps with face detection, HDR, and FaceTime over Wi-Fi or Cellular.
It has 3.5-millimeter jack featuring 16-bit/44.1kHz audio and active noise cancellation with dedicated mic support; Wi-Fi 802.11 a/b/g/n with dual-band and hotspot support; Bluetooth 4.0 with A2DP support; GPS with A-GPS and GLONASS support; and USB 2.0 reversible connector. It doesn’t have FM radio. It has built-in fingerprint, proximity, compass, accelerometer, and gyro sensors. The pre-installed Safari browser supports HTML5.
Java is not supported. It runs on non-removable 5.92 Wh Li-Po 1560 mAh battery with standby time up to 250 hours both on 2G and 3G. Talk time is up to 10 hours both on 2G and 3G. It is available in space gray, gold, and white/silver colors.
