Apple iPhone problem in my iPhone 4s
How can i create apple id without error (0x800b101) … and Bluetooth problem i want to have solution now thank you
Check your iPhone’s internet connection. Sometimes, I, too can’t connect to some sites or log in to some sites successfully because of poor internet connection. But if you’re still having difficulties for Apple ID registration to your phone, you can try to register using a computer through site: Create your Apple ID
The information that you need to fill in are well explained and you will not encounter any error if you enter information as what apple need from you. After you sign in using a computer try to log in using your iPhone and see if there is still error. If there still error, maybe the error is on your phone, internet connection.
Please check that.
