Apple Iphone Producing Sounds Whenever I Dial-how to turn off
I have a brand new Apple Iphone which gives me problem on operating. The keypad produces a lot unnecessary noise whenever I dial. I would love to do away with this keypad tones since it makes a lot of noise, but I don't know how.How do I turn off keypad/keyboard sounds when dialling on Iphone?
Answered By 5 points N/A #181047
  Hi Dustin,
I hope you are enjoying your Iphone, It is amazing piece of gadget.
You can turn just turn the iphone's silent mode on, by flipping the mute button on the side of the Iphone, slide it till you see red bar appears and feel the vibration, you will also see a message confirming that silent mode is on.
You also always can turn down the volume to minimum before dialing, This way you won't hear the dialing sound that bugs you.
Here is an image for illustration
