Apple iTunes, the program can’t start for missing file
50 points
Posted on - 07/17/2013
I am trying to start Apple iTunes but the program can’t start because the following error shows “AVFoundationCF.dll is missing”. Can I fix this problem without having any problem? I really need your assistance to remove this system error.
I would be grateful to you.
Error: The program can't start because AVFoundationCF.dll is missing from your computer. Try reinstalling the program to fix this problem.
