Mickhel
70 points
Posted on - 10/06/2011
I am using apple laptop . It is very popular in these modern age. It is so easy and comfortable to me.
But I do not comfortable to use it with  headfree . Because when I use it with my laptop , there is noÂ
connection between it . I do not understad what is the problem it is . Can I use another headfree orÂ
it is a problem for my laptop or anything ?
Linda
Apple Laptop is easy to use or not
I also use an apple laptop. it is very popular. it is very comfortable and easy. I am sure that the problem is in your sound card of your laptop. please replace it or repair it for using it comfortable.
It is sure that apple laptops are very popular in this modern age and working very properly. It is very comfortable for all users. So the problem which you are facing is not relative to the quality of the products of this top growing company. If you have some fault in your own laptop it is due to disturbance of your own behavior not responsible for it apple company. Because hands free system is constructed in all apple laptops except those which having the functions like Bluetooth or like WiFi connections. So it is clear that first of all you must be check here that, is there the function is available in your laptop for hands free. If no, than check for Bluetooth and please use the Bluetooth device for listening anything present in your laptop either music or anything. And also i have a request to please be sure about your problem and do not blame any company having such type of good reputation.
