eshiv1190
Posted on - 11/13/2013
Apple Maps Vs Google Maps
Which of this is better and reliable?
What technologies or mechanism do each of them use
What are all the devices each of them work on
Why 2 different maps with such huge expense rather then one great Map
Hi Eshiv1190,
The Google Maps is better than Apple Maps because of the following reasons:
1) Google Maps are simple to navigate
2) It provides more accurate Maps than Apple Maps
3) The data provided by Google Map is more reliable
4) Google Maps flash the roadworks that might interfere with the trip
5) The mode of transport is more flexible when compared with Apple Maps
The Google Maps uses the technology provided by Google. The Apple Maps use Apple technology.
Google Maps are supported on Android devices. Apple Maps are supported by all iOS devices.
Here is a side-by-side comparison of Apple map vs Google map.
Map view of San Francisco –
Google in the left and Apple in the right.
Apple looks crisp and clear, but presently they are completely devoid of useful information. Comparing side by side image of the lower Manhattan and San Francisco it is clear that Google gives you more precise info than Apple.
Map view of New York –
Apple should use more detail, and here also the clear winner is Google.
Traffic –
On Apple map traffic looks slightly incomplete. Google map has more info and details.
Satellite View –
Satellite view, even you hardly use it, explains the exact story. Google map has presently more info in every level.
Overall Google map beat the other by some points. Google map is more reliable and easy to use.
Hope it helps!
Thanks
