Apple Powerbooks G4 Turns Off After 5mins
I have an Apple Powerbooks G4.  Somehow, it turns off after 5 minutes.
I tried checking the battery but it seems ok.
I cannot install my choice of operating system: osx due to this problem.
I have doubts that this is due to an overheated computer since it does not feel hot.
Please help me solve this problem.
Answered By 10 points N/A #105071
Hello there!
If it is not your power supply that has a problem, then it is your machine's. Try resetting the power manager by simultaneously pressing and releasing Shift > Ctrl > Option > Power on the keyboard. Then wait for 5 seconds and press the Power button to restart your computer. If you have a g4 dvi and g4 1 ghz/867mhz, disengage the keyboard latches and the keyboard locking screw. There is a reset button by the upper right side of the logic board near the power button. Press and release it and again, wait for 5 seconds before you restart your computer.
If this does not work, try resetting the PRAM by pressing and holding the Command > Option > P > R keys down simultaneously before the gray screen appears.
Hold these keys until the computer restarts and until you hear the startup sound for the second time.
Good Luck!
