I want to use Linux operating system but I have heard that Linux operating system supports different softwares than the normal ones. I will need to use a set of apple softwares in my pc and I need to know whether there are apple softwares available for Linux. Please some one help me take the right decision.
Bruce Norway
Apple softwares for Linux operating system
I don't think there is a way to do that. I guess you are thinking on something similar to Wine for Mac or so. The installation process on Mac is unique and I don't think it is possible to install such programs like Linux.
Confusing about apple softwares to run on Linux operating system? Yes it a matter of thinking. As far it is known that there is no cope to run apple softwares on Linux operating system.
But I suggest you to move on Linux operating system.Linux operating system supports different soft wares than the normal ones,there is no doubt.Linux operating system is really good.
It is free and open source.There are many versions for many purposes. So,you have a opportunity to choose right one.
And again anyone can edit or modify the operating system for his or her own purpose.Now there are many useful application softwares have been developed for Linux operating system.
