Apple Wireless Keyboard shortcuts not working
Guys,
I cannot use my Apple Wireless Keyboard for adjusting brightness and volume.
I am trying to sort it out but failing.
Can you help me?
Guys,
Can you help me?
If you buy an iMac with Apple Wireless Keyboard, then your Apple Wireless Keyboard and Mouse were pre-paired for making setup quick and easy. For further adjustment follow the following steps:
Press and release the On/Off button on the keyboard to turn it off.
For delete the pair with Mac, choose System Preferences from the Apple menu, then choose Bluetooth from View tab.
Select the Apple Wireless Keyboard on the left side of the pane.
Click on the (-) icon in the lower-left corner to delete.
Now turn on the keyboard
For create the pair with Mac, choose System Preferences from the Apple menu, then choose Keyboard from View tab.
Click Set-Up Bluetooth Keyboard … to open Bluetooth Setup Assistant.
Then enter 8 digit passkey and press Return. (Do it quickly, it has a time limit)
The pairing will be complete by the process.
Some shortcuts for the Apple Wireless Keyboard work on iPad and iMac
F1 (Dim Screen)
F2 (Brighten Screen)
F7 (Back one song)
F8 (Play/Pause Music)
F9 (Skip one song ahead)
F10 (Mute)
F11 (Volume Down)
F12 (Volume Up)
