AppleID password reset from iPhone
Apple has restricted the password reset from Phones. Is there any other way to reset applied password from mobiles. Because app the time we may not have access to laptops and desktops.
Dear user,
Apple has stopped taking AppleID password reset requests over the phone.
Because there is a report that an account has been modified or infiltrate unauthorized by someone.
This is not actually disabling this feature. Actually there are changing their security policies and measures.
Meantime you cannot change your AppleID from your phone.
And you shouldn’t try to, apple does this in order to make sure your security safety.
But the feature will be available pretty soon. So you can do it from your phone.
Thank you.
If you forgot your Apple ID password and you cannot log in to your account, you can reset your password to regain access to your account. But to be able to reset your password, you need to remember the email address you used for your Apple ID.
On the other hand, if you also cannot remember your Apple ID, go to If You Forgot Your Apple ID to learn how to recover your Apple ID. Now, to reset your password, go to the Apple ID sign in page and click “Forgot Apple ID or password”.
On the next screen, enter your Apple ID then click Continue. After this, you can see how to reset your password depending on the security features you applied on your account.
For example, if you know the answers to your security questions, select “Answer security questions” then follow the succeeding instructions how to reset your password. If you select “Get an email”, Apple will send an email to your primary or rescue email address that you can use to reset your password.
