Applicability of office 2010 emulator to older versions
What is office 2010 emulator and how it could be used by users and state its compatibility with other programs in brief?
Hi, office 2010 is same as like previous version. You will get all facilities of your previous version from Microsoft Office 2010 but here is some additional options you will get including icon based commend which has made this software so easy to use. All the icon you will find on the top of the screen. If you want learn the using procedure of this software I will recommend you please go to www.youtube.com and just type how to use office 2010 and you will see all the commend in video as per proper instruction. Thanks.
Hi Abigail,
Here are the best features of Office 2010:
* Backstage View – This will help you to easily edit the settings of your page, preview page and printer. You can also save your file in the local folder and on the SharePoint server.
* Paste Preview – you can now customize the Page Preview of your file in Word, PowerPoint, Excel, Publisher, and Outlook.
* Screenshot – Having a hard time in getting your screenshots? Opening and finding your files where you save your image? In Office 2010 you can click the "Screenshot" on the ribbon then it will give you the recent screenshot you made and save.
* Editing Picture – You can now edit your image directly without using any application like Adobe Photoshop because there are many options you can choose to add effects to your image like sharpen, adjust color etc.
* Embedded videos – Adding video in PowerPoint is easy but are you confident to play it in front of everyone? In Office 2010, you can embed your video no need to locate it and you can also make sure that your video is really playing. You can also edit your video directly and remove some parts that you don't what to view.
* Video Presentation – You can now create a PowerPoint as video presentation for sharing it to your social media account such as YouTube. Common presentation that usually post or share to YouTube is a tutorial.
Amazing features right? If you want to install it to your computer, these are the system requirements:
* Operating System – Windows 7, Windows Vista, Windows XP
* 32bit and 64bit
