The application AppleMobileSync quit unexpectedly
Hi guys,
While attempting sync iPhone running with up to date Leopard I received an error message.
The screenshot of the error message is as under. Note that my iPhone have never compromised. Have you any idea?
How can I get a remedy of this issue? Please help.
Thanks in advance.
Mac OS X and other applications are not affected
The application AppleMobileSync quit unexpectedly.
Mac OS X and other applications are not affected.
Click Relaunch to launch the application again. Click Report to see more detail or send a report to apple.
Best Answer by Montelongo S Lockhart
Answered By 0 points N/A #190456
This is an issue which a lot of people face and there has been no clear solution from Apple just yet. However a few changes MIGHT help you. The issue arises when the sync for .MAC Is enabled. So To  stop them just turn OFF all syncing for .MAC And the errors should stop.
That's it!
Answered By 0 points N/A #190457
Hi Joseph, no need to worry.  There are a few things to do to solve your problem.  You need to reset first your sync history and after that you have to open iSync in the application folder then choose “Preferences”.   Next thing to do is to click “Reset Sync History” then it will fix your problem.
