Hi, I have the best program which I have ever used which is called Boomerang Data Recovery”.
It recovers the data very well and gives out tremendous results.
However after using it twice with good and excellent results the program began to fail give me an error “cannot connect to server”.
What could be the problem is any one using this program and experiencing the same problem what could be the solution for this?
I desperately need this program for me to be able to work who is out there who can help me.
Is this program made to be so good at first for making money?
Somebody please assist.
Application of Boomerang Data Recovery
Boomerang Data Recovery is a data recovery tool that enables you to recover files from almost any sort of media devices. You can recover deleted files, folders or partition.
Boomerang supports media devices such as hard drives, firewire drives, USB drives, microdrives, camera cards, flash disks, RAID volumes. You can recover deleted files even if the hard drive has a corrupt file system.
Boomerang Data Recovery system requirements:
Windows
Windows 98 Second Edition, Windows Millennium, Windows NT, Windows 2000, Windows XP, Windows Vista
256 MB RAM
Available space to save the recovered data
Internet connection
Mac
Mac OS X 10.3, Leopard or higher
Power PC or Intel based Mac
512 MB RAM
Enough space to save the recovered data
Live internet connection
If you are receiving a “cannot connect to server” error, check your internet connection if it is still active. I think this application requires a permanent active internet connection. It constantly connects and communicates with its server.
If you are using a demo version, maybe it stopped responding and requires you to register the application to be able to function again.
