anonymous
7060 points
Posted on - 04/12/2013
Im making a flashmovie cartoon. Everything has worked fine. Begun on a new scene today and when i hit cmd enter (play) i get: "Application descriptor file cannot be parsed." what? I don't even know what that means? What to do? What is the Application Descriptor? What is parsed? I'm so lost…
Application descriptor file cannot be parsed – Using Flash CS6
Hi there Anonymous,
Several things could cause the problem you're getting. One of the most common, and the one you should start with is the name problem. In case your file name contains any spaces or ampersands  you will get an error while parsing the movie. This is easy fixable – just rename the file you're working on to be simple letters and number name.
Another thing that usually cause this error is wrong Java version. Check if you are using the 64-bit Java, and replace it with 32-bit, as the software you're using is not compatible with 64-bit Java.
Best regards,
Drake Vivian
Application descriptor file cannot be parsed could mean application descriptor file missing/cannot be opened. What you should do is to check the application descriptor file for XML syntax errors such as unclosed tags.
Every AIR application requires an application descriptor file. The application descriptor file is an XML document that defines the basic properties of the application. Many development environments supporting AIR automatically generate an application descriptor when you create an object. Any filename can be used for the application for the application descriptor file. When you package the application, the application descriptor file is renamed application.xml and placed within a special directory inside the AIR package.
Parse is a complete technology stack to power your mobile app’s backend. Parse is the cloud app platform for windows 8, windows phone 8, and iOS, Android, JavaScript and OS X. With parse, you can add a scalable and powerful backend in minutes and launch a full-featured mobile or web app in record time without even worrying about server management. Parse offers push notifications, social integrations, data storages and the ability to add rich custom logic to your app’s backend with Cloud Code. Build more with parse. In computers, to parse is to divide a computer language statement into parts that can be made useful for the computer.
There might be something wrong with the installation of the software or the java components on your computer. Side by side aforementioned solutions also check out this Techyv post because this post is addressed your problem too.
Flash CS5.5: Application Descriptor File Cannot Be Parsed
