Application does not get installation
Guys, I am using Mac OS X and I love it. But I hate it when it doesn’t allow me to install apps on to it. This time I tried to install Pod Farm and despite of installing this easy application it gives me an error suggesting me to that “The installer encountered an error that caused the installation to fail.
Contact the software manager for assistance”.
Following is the screen shot of this:
Best Answer by Hoting Gracia
Answered By 5 points N/A #103214
Hello Noel its so sad to hear that you are facing the problem with most lovable Mac Operating System and be cool when the problem arises at the time of installation.
The error may be caused due to problem with your system or else problem from your application end but remind that problem may consists in both at rare cases.
The error you might be getting is an easy one to be solved and it can be done in 2 ways one is that its better to check your system and ensure that all files are present and nothing are being missed.
Another issue is that it may be due to the missing of file in the application or else uninstall the completely related to it and then re-install again as there is a chance to solve the problem.
Thank You.
Answered By 590495 points N/A #103215
I’m not sure if the problem here is with your installer of POD Farm or the installation just encountered an error. If you downloaded the installer of POD Farm, maybe it encountered a problem while downloading it and made the file work this way. If it is an incomplete download, you will receive a different error message and not like this one.
Try downloading the file again from the same website where you downloaded it first. If the same problem occurred on the new downloaded file, try downloading it again but this time in a different website.
POD Farm supports Mac operating system and I’m sure you don’t have any incompatibility issue here. But just to make sure that your system is pretty much compatible to run this program, see the details posted at this site and then verify your computer.
Answered By 10 points N/A #103216
Thank you Hoting Gracia and Sharath Reddy.
You're both of great help! I discovered that problem is with the installer. It must be missing some files.
Thanks TechyV.
