Application Error 0x3003a657: Could Not Access Control Panel
Every time I executed the Task Manager and shutdown or restart my computer, I keep getting the message error “dwwin.exe Application error…the instruction at "0x3003a657" referenced memory at "0x00a65a4d", the memory could not be "read", click OK to terminate the program” and such. Aside from this, I’m currently unable to add and remove programs, and use other utilities in the Control Panel. I’ve tried fixing the problems by downloading software which fixes my registry, but still no luck. I’m really at the end of my wits; any form of help is deeply appreciated.
Best Answer by Brooke Kstri
Answered By 0 points N/A #113480
Possible cause of this problem:
1.      Your computer might be infested by malware so use an anti-virus and cleanup it
2.      System file may missing from system directory so repair windows with a CD/DVD
To fix Desktop Windows manager or dwwin.exe you used registry cleaner third party software). Make it manually _
1.      Click start .
2.      Then select RUN program
3.      Type REGEDIT
4.      Find this location: HKEY_LOCAL_MACHINE SOFTWARE Microsoft Windows NT CurrentVersion AeDebug
5.      Now set value
6.      “auto” value: 0
7.      Reboot your system
Hope It will work.
_ Brooke Kstri.
Answered By 80 points N/A #113481
Hello Heide,
May I suggest you to reinstall or change the operating system that you are using right now because it may not be compatible in accessing your control panel or other application that you are using.
To change your operating system, you can perform the following steps in the link below for you to decide on what operating system you want:
https://www.techwalla.com/articles/how-to-change-an-operating-system
I hope it helps you solve your problem. Good luck and have a great day!
-Zorian
Answered By 0 points N/A #113482
Wow, Brooke Kstri gave me a very helpful step by step guide. I followed it, I run regedit and located HKEY_LOCAL_MACHINE SOFTWARE Microsoft Windows NT CurrentVersion AeDebug. Then, I changed the auto value to 0. Restart the system and done! Thank you very much!
