I created an application in a certain website for my HTC Desire Android Smartphone, but I got an application error when loading it.
I tried it on other phone such as Samsung Galaxy Ace and it’s working perfectly fine.
But I can’t make it work in my HTC phone.
How can I fix it?
Application Error
The connection to the server was unsuccessful. (file:///android_asset/www/index.html)
Application Error in my HTC Desire
Hi
The problem you are telling with your HTC is not working properly this is because your internet proxy on you cell is not correct so you have to change your proxy settings according your internet. So let first know from your internet connection then this will sort out.
When you are checking this on the Samsung galaxy then the internet proxy is correct for the internet you were using on so first correct your internet proxy then it will start working and this application will start working and installing and running on your HTC. Hope this solution will help you getting out of this problem. If not then you check whether your HTC android OS is compatible with the application you are using.
