jovyhasle
1170 points
Posted on - 07/14/2011
Hi guys,
I am having a problem while using TogglDessktop, while I was using the application, a message box suddenly appeared, with its message of, the application failed to initialize properly (0xc0150002).
Click OK to terminate the application,
Please see below the error message I pasted.
TogglDessktop.exe – Application Error
The application failed to initialize properly (0xc0150002). Click OK to terminate the application.
This is my first time to see such error message, I don't remember doing some setting changes before this error message came about, I have already done restarting my computer, I even reinstalled the application, but same error message will occur, at any given time while using the application, please help me with my problem, thanks and more power techyv.
Banaay22
Application error received while installing TogglDesktop
Hi im henry,
I am computer network technician, I encounter this kind of problem, there is some of file are missing.
And also the changes of your computer setting, Or some file will be corrupted.
Regards
Henry
Boboy99
There are various ways to get rid of that error message. If uninstalling and reinstalling won't work then there should be some major updates that need to be done to the system to keep programs running stable.
Please be guided by the following given below:
One major update that needs to be done is the Direct x. Download the latest Direct x available by typing the phrase in the search engine.
Install the latest Service Pack. Service Pack is one of the major update and is essential for programs stability and compatibility of software in a system.
Net Framework: Download and install the latest .Net Framework available. You can search it from Google or just type the phrase.
Download and Install Visual C++Â redistributable
