Application error using Blu-ray converter Ultimate
Hello Professionals,
The download and the installation of beta version went pretty well and good without any problem. But the problem triggered as soon I start the application, it then immediately closes the program. Is there any system requirement for this? I have windows 2012 operating system. Hunting for solution please help me. Your help isreally great. Thanks.
Application Error
Exception ElnvalidPointer in module BlurayConverterUltimate.exe at
00005BF5.
Invalid pointer operation.
OK
Answered By 590495 points N/A #185057
Even if you are using the latest version of Blu-ray Converter Ultimate, I don’t think it will run on Microsoft Windows 2012. If you want to use Blu-ray Converter Ultimate to convert your Blu-ray discs, you need to shift to a different operating system because Microsoft Windows 2012 is not supported. Download the latest version from Blu-ray Converter Ultimate 3.0.0.20.
This version supports Windows XP, Windows Vista, Windows 7, and Windows 8 both x86 and x64. So to fix your problem, you need to do a clean installation using any of the four supported operating systems. If you will be converting from Blu-ray, you need to install a program called AnyDVD. It is a Blu-ray decrypter required in Blu-ray conversion.
To download, visit Download AnyDVD.
