Application Error while playing Dungeon Fighter Online
I got this error message while playing Dungeon Fighter Online. This error appears randomly without warnings. My game will just stop and then the error will appear and end my session which leads me to start anew simultaneously. To those who are having the same problem as mine please tell me how I can fix this? Thank you very much.
DFO.exe
DFO.exe – Application Error
The exception unknown software exception (0xc0000005) occurred in the application at location 0x068310ba.
Click ok to terminate the program
OK
Best Answer by Akol ben
Answered By 0 points N/A #124240
Try changing the compatibility for DFO executable. If it doesn't work, you can also try this, assuming your hardware is good enough. Check out:
Windows XP Mode – Windows 7 features – Microsoft Windows
Also, consider your hardware if it is good enough with others or your friends that are playing with it or it is not compatible with them. 32 bit OS is much wider used than 64 bit OS. Your friends may be using different hardware or drivers that allows DFO to run without issues.
Answered By 10 points N/A #124241
The first thing that you need to do is to do system repair/upgrade. This would fix any corrupt files. Although this would not effect your data but still you should backup your data. This should solve your problem. Or you could try updating you windows for any driver updates or any other updates. I hope you find the solution.
Peter franklin
