Robert Dee
Posted on - 07/04/2011
I was playing grand theft auto 4 this morning and suddenly the game crashed. I was at the peak of my game when this happened. I admit that I use some third party software or programs to cheat my way into the game. I still can open my game because it only shows a black screen and prompts the same message "Exception EFCreateError in module carspawner.dll at 00011469. Cannot create file “C:Program FilesRockstar GamesGrand Theft Auto IVspawnlog.log”.Accés refuse."
Anyone knows the solution for this?
Application Error while playing GTA 4
Well the error you are facing is not in your game. The carspawner.dll is windows 32 applications and its create problem when broken/invalid or even infected by malware or virus. The system and application will conflict. There are some ways to solve your problem and i will tell you first the easy way to solve your issue. Just copy carspawner.dll file from another same operating system. It was the easiest way.
Here is a video to watch how to fix this file.
The second way to solve your issue is through a software Smart PC Fixer
Here is the URL to download.
It looks like you have used some kind of car spawner for spawning a car during the game and that is creating problem now. Uninstall that software and then restore the system to the point when this problem was not there.You can again install the game and then play it whenever you like. I hope you will find this to be the easiest way to solve your problem.
Waters Magner
