The application failed during registration
Good Day to all,
Good Day to all,
Hello Nielsmel,
Your problem is generic one and the only this type of error appears when there is a problem with the software. I simply want to tell you that whatever software you downloaded is not accurate or may be there are some missing files in it.
So if you want to fix your problem then I strongly recommend you to don’t download any type of software from those sites which you are not sure about and always try to download software from authentic and authorized websites.
The advantage for this is that you never face any type of problem and also there is no any verification required for that software. So your problem is that you can now download it again but make sure that firstly you can remove all of the previous files of that software. It’s better if you download that software directly from the site of that application.
I hope it will solve your problem.
THANKS.
