The application has failed to start
I am using Visual Studio 2010 Professional using the Win 7 Professional. I am trying to run the C++ program using this system config but every time I get the following error message when I try to start the program. You can help me with the help of the attached error image below. Please provide any suggestion to fix this problem. Any idea would be grateful. Thanks.
D:PortableAppsXnConvertxnconvert.exe
The application has failed to start because its side-by side configuration is incorrect. Please
See the application event log Or use the command-line sxstrace. Exe tool for more detail.
