Hi experts. I'm having troubles installing resynthesizer plug-in. Every time I try to run it, the screen pops out with an error. As you can see in the image below, the error says that intl.dll was not found. I have not touched the installation folder. If someone knows how to solve this, please help me. I will be very grateful
Resynthesizer.exe – Unable To Locate Component
This application has failed to start because intl.dll was not found. Re-installing the application may fix this problem.
Since the problem is in the plug-in you installed, you should check if it supports the program because it can’t seem to find the file specified. Sometimes when you install third-party plug-ins that don’t come with the application, you need to check with the developer or the website on what versions it supports because sometimes this is where the problem starts.
Since you didn’t mention the program’s name, try reinstalling it. Uninstalling the application will also remove the plug-in. Uninstall the application, restart your computer and install it back but don’t install the plug-in yet. Run the program and see if it works. If it runs, try installing the plug-in this time and run the program again. See if the error is reproduced.
In case the error appeared again and still associated to “intl.dll”, try downloading the DLL file from Download and Install intl.dll. Once downloaded, unpack the ZIP file and copy it to the installation folder of the program requesting it or to the installation folder of your program. Try it again.
