This application has failed to start because MSVCR80.dll was not found
Hello Guys! I hope someone can assist me to solve this simple problem for those experts here. Please help me about this error. I installed Office Enterprise 2007 to my computer. All office programs throw an error when I am trying to run it. Some post suggest that I need to remove Anti virus to my computer, so I removed.
But the error still there and I don’t know why. I also tried to re-install the program but still get this error.
What can I do guys? Please tell me.
Error:
helloconsole.exe – Unable to Locate Component
This application has failed to start because MSVCR80.dll was not found. Re-installing the application may fix this problem.
OK
Best Answer by fortunewaybd
Answered By 0 points N/A #118753
Reason: Error message shown due to msvcr80.dll has deleted or altered by another program
Do:
  1. Repair your existing program
  2. Reinstall it form DVD .Perform a clean reinstallation
  3. Search the dll file and copy it into the safe place.
  4. Note down where you copy it.
  5. Install antivirus and check that the dll file is missing or deleted. If not then check whether it is altered or not.
  6. If file is changed or deleted then copy the dll file and paste it into the destination.
Answered By 10 points N/A #118754
Hi Jamby,
This msvcr80.dll is a system file and you can remove the error by using Microsoft Security Essentials.
Follow these steps to download these Essentials:
1. Click on this link – https://support.microsoft.com/en-us/help/14210/security-essentials-download,
2. Select your Windows Operating System from the drop down menu and Press Download,
3. Run the Essentials.
I think it should solve your issues.
