martyables
1170 points
Posted on - 06/28/2011
Hi all,
At work, I have a lot of files in my computer. That is why, I planned to back up all in a CD. My office mate advised me to use CDBurnerXP, because they are using it for some time already .
So I downloaded a copy of it, and installed at my computer. After installing it, I wanted to try it. When I run the application, error message was displayed in my screen. I pasted below the screen shot.
The debug log could not be enabled: Cannot delete a subkey tree
because the subkey does not exist.
After I read the error message, I suspected that its just an error of CDBurnerXP not with my computer, since my computer is running without a problem before I installed CDBurnerXP. For those who have tried the same error, please share some ideas.
george23
Application not running after installation
There is something wrong with your registry. Do you have a registry checker or program installed in your pc. I would suggest using scanreg for instance and have a diagnostic run on you pc. You might not feel it in the performance of your pc but errors like these could lead to corrupted files being left on your unit after installation. Its a 90% chance that you will find the error or the update there. Be careful when adding new programs on your pc, it could also affect the registry of your pc.
It is also good to have your pc updated as often as possible, the new updates and programs adhere to the changes needed by the system in order to function properly. If you say the problem is in the disc, can you try to use the disc in another pc to check if the installation would go thru. I would like to recommend buying CDs/DVDs that are built of quality not of quantity. Avoid yourself the headache of having problems like these by sacrificing at least a small amount of price difference. Or you could also try to use another burring application, Nero for example is quite effective.
I hope this post helps
