What are some of the Android apps that can assist the blind in their daily routine lifestyle? I am Lois from one of the Central African countries. I would like to know if you can assist me to find the best five Android Applications for the blind who uses Android Smart Phones or tablets. Thank you.
Application Softwares Developed by Android Developers for the Blind
How are you? Android is a resourceful invention of technology that also includes certain applications that help visually impaired and blind people in functioning. Some of these applications are:
1: Ideal Accessibility Installer : This application is also called Platform Access Installer. It contains different packages such as KickBack, TalkBack and SoundBack (TKS) applications for visually impaired and blind people. These applications add audible, vibration and spoken feedback to Android devices. After you have installed the application, go to Settings, Accessibility and check the applications that you want.
2 : ScanLife Barcode and QR Reader : Visually impaired people can also benefit from a miraculous application called ScanLife Barcode and QR Reader integrity in this technology. The user only needs to click a picture and the application the rest of the magic. The app can read QR and UPC codes. After the codes are scanned, the application starts reading the embedded string as QR codes.
Moreen Jamnelly.
