kate osmond
Posted on - 10/28/2011
We usually buy software online so we can avail the maximum performance of each one. Sometimes, we buy without thinking if it will work or not. Some provides a trial version but how do we really know if the ones we are buying is efficiently working.  Is there an application or a process that we could test the software’ existence to other software that is already installed on a computer and requires intercommunication with the user to continue testing? Do you have any suggestions about my query?
wakish
Application to test a Software
One the first procedure to obtain an efficient software is first to do a market research and to obtain answer of the persons who have bought the software in line(figure) and the best place to obtain the software. that way first of all we have eliminated one of the worries. the following thing that he(she) would advise him is so that you obtain to a changing room of the reasonable changing room it is Rapise.
Rapise is a tool of automation of the test of the software of following generation who makes use of the architecture potency opened to improve the quality of the application and to limit the time to the market.
Using advanced technology and an extensible architecture, Rapise can handle its needs for tests of cross-browser and application of software.
Hi…
This is a really interesting question. Most of us are facing these kinds of problems every day.  There are thousands of face software’s in the market. Especially it happens when we buy a new software online.
The best solution that I can dive you is go with the brand name. If you found a same kind of software from the two different sellers always buy it from original seller. Do not think about the little extra money that you pay.
Another recommendation is to use portable software’s if available. It is easy and very useful technology.
To do the exact testing you required is not possible. But you can do a good research to identify the quality of the software that you are going to buy.
Thank you…..
