The application TouchPhases has stopped unexpectedly
Hi there,
This error appeared in TouchPhases when I have connected my android phone to my PC. I never had this kind of error before and everything worked fine. Now I am stuck with error and please is there an expert online that can help me with this ? Is something wrong with my phone ?
Thanks !
The application TouchPhases(process com. Unity Technologies. TouchPhases) has stopped unexpectedly. Please try again.
Answered By 0 points N/A #181822
Hi Roger,
You can close the application first. It happened for some reasons like there are many applications which are running at the same time or you installed another application or feature that is not supported by your device. You can turn off your device then update your application. If the problem still exist, uninstall the application and install it again. I recommend to re-install the application so that it will clean all the issues found when the application is running.
