simanto632
Posted on - 09/15/2011
Hi dear,
I have a problem on my computer. I want install this Application but all time i failed. I do not know what's the problem. Can anybody tell me, why i see this message?
"Application Virtualization Error
The Application Virtualization client could not launch smartplant instrumentation 8.0.3.9977.
The operation failed because you do not have sufficient [Permission to stream from a file.
Report the following error code to your system administrator.
Error code: 4615186-14902204-00001808"
I can not understand this message. So i need help for understand this error message. Please quickly help me by your important answer. Thanks
alphae
15 points
Application Virtualization Error in Windows 7
So you when try to launch application every time on your PC the error appears. If you are trying to install a beta version then it could be probably have expired so try getting a genuine full version. If the problem persists then run system restore to remove any programs or updates that you might have installed that are responsible for bringing that error. You can as well go to the control panel and select the programs that you installed most recently that you greatly suspect may be causing that. It might also be because of malwares so you could consider performing a full scan to your system.
Hope this helps
-alphae-
