Applications using sqlite3.dll fails to launch on pc
Hi friends,
I am unable to use some of the programs installed on my computer after I downloaded the Bitdefender antivirus. On trying to launch the application, I get the error message “None of the dynamic libraries can be found: sqlite3.dll”. I installed the 30 day trial version of Bitdefender Total Security and on getting this error, tried using Bitdefender Antivirus Plus. I’m still getting this dynamic libraries cannot be found error. Is this a problem with the antivirus download or is there a work around for this problem? I would like to continue using this antivirus as I really loved some of its features. Please advice on how to fix this problem. Many thanks for your help.
None of the dynamic libraries can be found: sqlite3.dll.
