donaldtbyrd
50 points
Posted on - 01/25/2013
Can anyone recommend a good application to clean up junk file for iPhone? I have an iPhone 4S which is not yet jail broken, and most of my deleted applications seem to have left a part of the program on the registry of my phone. I would appreciate a free application to clean up junk file in iPhone.
Apps to clean up junk file for iPhone
Hi Donaldtbyrd,
If you want to clean your junk from the iPhone so do not worry about that you can do it easily by using a camshaft junk cleaner. In which you can also get more features like File management , file extension and another one application is mobile junk cleaner is also an excellent application for junk remover. Hopefully this information will help you.Â
Thanks,
Raun Nelson
Hello Donaldtbyrd,
You can use "icleaner" to clean up junk files for iPhone. icleaner is the best application for deleting junk files. It also frees up spaces on your jail broken iPhone. While researching I have found many junk file cleaner applications, but it seems to me that icleaner is the best one.
You can try this. You can download this application from here:
https://itunes.apple.com/us/app/icleaner-for-iphone-ipad-ipod/id599923235?mt=8
