Hi! I would like to know if I can watch live streaming on Samsung Wave. I've recently switched from Samsung Galaxy Y to Samsung Wave and I wanted to watch some sports and news live. Is there an application that I need to install to watch live streaming on Samsung Wave?
Apps to live stream in Samsung Wave
Hi there,
Yes, you can surely watch live streaming videos on your Samsung wave handset however for that you either need a compatible plug in or an application.
However most importantly before you can further you need to get in touch with your service provider to in order to activate the appropriate application of features.
Hope this helps.
Thanks
Baker
Hi Kiersten,
Yes, definitely. You can watch live streaming video on your Samsung Wave phone by using the Live Internet TV Application. By using the application, you have the privilege to watch live streaming videos, movies and television shows. You can download the application directly through your phone or just following the link provided below.
The link will direct you to a website where you can choose from different live streaming application that is compatible with Samsung Wave.
Ware
