Hi. I have a question here. Is ArchiCAD 7 Mac compatible? I have an iMac with Intel Core i5, 8 GB RAM, 512 MB Nvidia GeForce 640M Graphics Card and OSx Mountain Lion. The program just gives a white screen then crashes. Thanks in advance.
Is Archicad 7 Mac OSx Lion compatible?
Greetings Roger Garison,
It seems that you have a version greater then 10.6 OS X meaning that you can't open programs that require Rosetta.
I'm not entirely sure that that's the problem you have, but you can read this article about it.
In order to run Archicad on your Mac you need Archicad 10 or greater.
I hope I solved your problem.
Regards.
It is compatible, but it seems your application is corrupted. Try to reinstall your application, if that doesn't help, then please install the newest version of Archicad using this link: http://download.cnet.com/s/archicad/
This version will provide you with the newest fixes and patches; that should fix your problems.Â
I hope I helped you.Â
Regards.
