I want to archive files based on date it was last accessed. I want to lessen my files and there are loads that I do not need at the moment or not ever so I want to archive them based on the last time it was opened/modified. Could this be done? Any software I have to install or something?
Archive files based on date it was last accessed
Good day my friend,
You need a File Manager Software to do this. You may consider this Professional Software. It might be the right software for you. Click on the link to download and check here for further information about the software's feature. You may need to spend a little to be able to use this great software. If you want free File Manager Software instead. Well, here's the list of link and try it yourself.
XYplorer Free
CubicExplorer
Ultra Explorer
Master Commander
To find more about free File Manager Software. You may consider this link instead.
Hope this helps.
