Are digital catalogues in psd editable?
We are launching a special anniversary issue of cosmetic products brochure. My crew has sent me a draft of the catalog via email that I have to check. The file was saved in .psd format. Can I still edit the catalogs in psd format for possible changes? Can I convert the file to other image formats?
Answered By 0 points N/A #165631
Hello Warcup!
Sorry about that problem, the answer to your question is yes, there are many software applications that can be used to convert psd files to different image files such as MPEG, JPEG, GIF, BMP,TIFF,PNG,JPG and over 20 other image formats. I can advise you to download a software that can do this very first. Depending on the operating system you are using, If you are using Windows XP, vista, windows 7 (pc).
You need to visit http://convert-psd-to-image.software.informer.com/
Click on the second Download button on your left which is light green in color, (when you move the cursor over it, it displays "Download Convert Psd to Image"
Select Save File
And wait until it finishes downloading.
Double click that downloaded file to install it on your PC
Open the file with the application and do what you feel you want with your file.
Hope this will be of great help to you.
