Are grisoft inc software trust worty?
Are grisoft inc software like AVG trust worty?
Does it do the job well? Or is it like other anti-virus scams where you can use for free then forced later on to pay for it?
Or does it install virus instead of removing it?
I have been a victim of anti-virus programs so please help me decide on this
Best Answer by Austin kelley
Answered By 0 points N/A #164030
It definitely won't install a virus but AVG is not a good choice anyways.
The detection rate is very low and you will not be satisfied with the security level.
It's better than nothing if you are not willing to pay for an antivirus but other antivirus applications are much better than AVG.
I recommend using AVIRA. It's more trustworthy.
Answered By 10 points N/A #164031
I advise you to use Avast Free Antivirus software because I have used this for several years in my pc as well as in my android phone.
No compatibility issues, no forcing to buy the full version, easily update to new versions and very importantly software will not reduce your PC performance.
You can download this using the site:
